Dop88
Jul 24, 2020Aspirant
LB1120 Not connecting to a cell tower
I purchased the NETGEAR 4G LTE Broadband Modem LB1120 along with a TP-LINK WiFi Router AC1750 to access a 4g LTE tower that is in visual distance of my location. I will be using it in a rural area an...
Dop88
Aug 05, 2020Aspirant
Just adding cell phones get a solid 4g LTE signal.
LlamaLarry
Aug 05, 2020Luminary
That is weird that none of the carrier SIMs are working. Does the SIM information appear correct in the webui (Settings -> Mobile)?
Any chance you're not seating the SIM properly and/or have the wrong size so it is misaligned?
I have both an LB1120 and an LB2120 and both were able to connec to AT&T LTE indoors without an antenna.
- Dop88Aug 05, 2020Aspirant
Thanks for replying. Not sure the steps to your first question. I had AT&T and T mobile insert the sims at their stores to make sure they linked up which they did. Never took them out, when I arrived at location they wouldn't link up. Just got the amber light which I let set several miinutes to see if it would complete the link up. Didn't happen. I don't know if the data only cards is the issue.
