dgs331's avatar
dgs331
Follower
Dec 24, 2019
LB1120 Not working
I purchased an LB1120 and an AT&T sim card.  When I turn it on, I get a flashing amber light and the third bar is lit green.  The first two bars are not lit.  I can't connect using the IP address either.  I noticed the sim card only had six connetors but the device has eight.  Is that correct?  Am I doing something wrong or is the unit defective?
