GroggyAcorn
Mar 19, 2021Follower
Lb1120 not working
i recently got an lb1120 and a netgear ac1200 router and when i set up everthing it looks fine they both turn on and seem fine no amber on the lb1120 everthings fine but when ever i connect to the wi...
michaelkenward
Mar 20, 2021Guru - Experienced User
GroggyAcorn wrote:
i recently got an lb1120 and a netgear ac1200 router ....
AC1200 is not a reliable guide to model number. Many devices come with an AC tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
How is the lb1120 configured? Router mode or bridge mode?
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Manage Router Mode and Bridge Mode.
You may have done this already. I can't tell from your message.
My guess is that you have two routers clashing with each other.
What is Double NAT? | Answer | NETGEAR Support
But that's just a guess, based on knowing very little about your setup, especially the router and how it is configured.
