mmessier2
Sep 20, 2018Aspirant
LB1120 on TMobile LTE being throttled?
I have an LB1120 with a TMobile SIM card that I have on an unlimited international data/hotspot plan. Recently I noticed that my speeds had decreaed to around 6Mbps from the typical 20-30Mbps. I lo...
mmessier2
One other item to note. I believe this is happened in the past. When I am connected this tower, which gives me a nearly full bar signal, my speeds are slow. When the modem is connected to a different tower, which has only 2 bars of reception, I get the higher speeds. Is there any ways to switch towers? Thank you
