Lbynaker
Mar 11, 2020Follower
LB1120 password
Password listed on the back of the modem won’t work out of the box. Tried resetting twice and that didn’t work either. Help!
1 Reply
Lbynaker wrote:
Password listed on the back of the modem won’t work out of the box.Which one?
Admin login?
Modem password?
If you need more help, you might get better and quicker replies, and find other answers, over in the appropriate section for your device:
Mobile Routers, Hotspots & Modems
No need to repost there, unless you want to – that will just clutter up the place with duplicated messages – but you might find advice related to your hardware.
I have asked the Netgear moderator to move your message.
