MrBunster
Oct 28, 2020Follower
Lb1120 power light solid amber and lan light solid green
This happened randomly an hour or so ago. Everything was working fine and then the power light stayed solid amber and the lan light appears afterwards, flicks a bit, then stays solid green. The five bars in the middle do not light up. I resetted, disconnected and reconnected the modem to no avail. I believe there's internet access, but do not know what to do to fix this issue.
1 Reply
- Blanca_ONETGEAR Employee Retired
Hi MrBunster
Welcome to NETGEAR Community!
Kindly check link below for the list of error conditions indicated by the Signal Strength LED bars and possible solution:
https://www.downloads.netgear.com/files/GDC/LB1120/LB112x_UM_EN.pdf [page 85 - 86]
Blanca
Community Team
