elvisimprsntr
Feb 19, 2017Aspirant
LB1120 Product Manual, Registration, and Firmware
BACKGROUND I received my LB1120 on Feb 15 and got it up and running without too much trouble. There was no Users' Manual included nor is there a UM on the Netgear support site. I had to use the...
- Feb 23, 2017
My APN configuration is likley irrevlent unless you have an ATT IoT SIM, but here it is.
SIM: ATT IoT
APN: m2m.com.attz
Complete list of ATT APN and characteristics: https://developer.at...characteristics
You can read my full post on IoT SIMs here: http://cocoontech.com/forums/topic/30141-low-cost-247-lte-failoverfailback-solution/?p=254004
elvisimprsntr
Feb 20, 2017Aspirant
Download the EU version Users Manual for instructions. http://www.downloads.netgear.com/files/GDC/LB1110/LB111X_UM_EN.pdf
ATT APN settings. https://developer.att.com/technical-library/apns/apn-descriptions-and-characteristics
- eightpointacresFeb 22, 2017Aspirant
I have the 1121 version, and while it did come up on the ATT network, its only performing at 3G speeds. I get 7Mbps, vs my 5 year old iPad at 23 Mbps from the same location. I spend over an hour with ATT last night and the sum of the conversation is that since its not a ATT branded device they don't guarrantee that it will connect as a 4G device! I am pissed. So I am going to try netgear support tonight to see if they will provide me the APN settings to get it to connect at LTE speeds. If anyone has any suggestions please reply.
BTW, I had the same problem with product registration! I registed mine as a LB1110 device.
