elvisimprsntr
Feb 19, 2017Aspirant
LB1120 Product Manual, Registration, and Firmware
BACKGROUND I received my LB1120 on Feb 15 and got it up and running without too much trouble. There was no Users' Manual included nor is there a UM on the Netgear support site. I had to use the...
- Feb 23, 2017
My APN configuration is likley irrevlent unless you have an ATT IoT SIM, but here it is.
SIM: ATT IoT
APN: m2m.com.attz
Complete list of ATT APN and characteristics: https://developer.at...characteristics
You can read my full post on IoT SIMs here: http://cocoontech.com/forums/topic/30141-low-cost-247-lte-failoverfailback-solution/?p=254004
elvisimprsntr
Feb 22, 2017Aspirant
I have no problem connecting to 4G LTE network with the LB1120. I suspect the APN, SIM card, or plan is preventing form connecting to LTE. Not all
SIM cards are equal. Cards are tied to your plan and the APN. I doubt Netgear will be able to help. See my previous post for the ATT APN settings not all APN will connect to LTE.
- eightpointacresFeb 22, 2017Aspirant
Maybe you could share you APN settings and I can find out if they work on my account. I have the 30G shared plan. What bothers me is that they are charging me $20/month for this device because its a "hotspot", but only $10/month for my 5 year old iPad, with much older radio support, yet I get 3x the performance on it! I would not have spent $140 on a 4G LTE device if I had known that I could not get LTE speeds. On the box Netgear even says that the 3G is a "fall back" speed. I will still need to speak to them about their claims for the device if I can't get it up top to speed. Pun intenteded.
