elvisimprsntr
Feb 19, 2017Aspirant
LB1120 Product Manual, Registration, and Firmware
BACKGROUND I received my LB1120 on Feb 15 and got it up and running without too much trouble. There was no Users' Manual included nor is there a UM on the Netgear support site. I had to use the...
- Feb 23, 2017
My APN configuration is likley irrevlent unless you have an ATT IoT SIM, but here it is.
SIM: ATT IoT
APN: m2m.com.attz
Complete list of ATT APN and characteristics: https://developer.at...characteristics
You can read my full post on IoT SIMs here: http://cocoontech.com/forums/topic/30141-low-cost-247-lte-failoverfailback-solution/?p=254004
elvisimprsntr
Feb 23, 2017Aspirant
SIM: ATT IoT
APN: m2m.com.attz
- eightpointacresFeb 23, 2017Aspirant
Thank you so much for all the detailed information. I will post for others benefit once I have a solution that I am happy with.
- Constant7Feb 24, 2017Aspirant
Thanks to both of you, I received mine yesterday and will be trying to get it set up this weekend.
