unidentified
Apr 01, 2018Aspirant
LB1120 question: how to use "device data" instead of "hotspot data"
I have set up my LB1200 with a sim card from a cellular device on my unlimited plan that I wasn't using. On this plan, there are two ways of using data on each line - the dedicated data for the devic...
t3k4t4k
Jul 21, 2018Initiate
You need to use custom firmware on a wireless router connected to the LB1120 that changes the TTL of the network traffic. Custom firmware is created for specific models of wireless routers only. Check out https://dd-wrt.com/
unidentified
Jul 21, 2018Aspirant
I'm familiar with DD-WRT firmware and would like to try it out. One question: How would changing the TTL switch from hotspot data to onboard data stream?
