mewhalen
May 25, 2017Initiate
LB1120 remote management
Is there ay way to remotely manage the LB1120 4G/LTE router? TR069? Thanks
mewhalen
Aug 21, 2017Initiate
I know this has been a while, but I am finally getting back to this. You state that there is no TR-069 support, however the spec sheet under key features on Netgear's site says otherwise. See link below...
https://www.netgear.com/home/products/mobile-broadband/lte-modems/LB1120.aspx#tab-techspecs
Any help would be greatly appreciated.
tr069
Oct 16, 2017Initiate
LS,
I would like to know or the technical specification are correct or not. Is there tr069 support on the units or not?
Thanks!
