j344
Oct 05, 2019Follower
LB1120 seems to use data, event when nothing connected
I got my new LB1120 setup on Google Fi and it works fine. I've found that the device uses data even when there is no activity. I entirely unpluged the router from the LB1120 for a day and found that even with nothing connected, the LB1120 still used about 3GB a day.
Is this expected? Is something setup incorrectly?
You will be best served by posting over in the mobile hot spot forum for this.
Good Luck.
j344 wrote:I got my new LB1120 setup on Google Fi and it works fine. I've found that the device uses data even when there is no activity. I entirely unpluged the router from the LB1120 for a day and found that even with nothing connected, the LB1120 still used about 3GB a day.
- Blanca_ONETGEAR Employee Retired
Hi j344
Welcome to NETGEAR Community!
May we please know the device SKU? A new firmware was recently released, kindly check if you have the latest firmware.
We suggest to contact your carrier and ask them to perform a billing investigation. They should be able to tell where the charges are coming from.Regards,
Blanca
Community Team
