ctu5000's avatar
ctu5000
LB1120 Setup
I have an LB1120 4g modem that I want to connect directly to an existing router (replacing the existing DSL modem) in order to provide 4g service to my home wifi network.  It will be using an AT&T SIM card/data plan.
Does the modem need to be set to router mode or bridge mode?
Is there anything that I need to change in the modem's configuration?
Thanks...
1 Reply
  • The manual says switch to bridge mode if you're connecting to another router.
