iskra092's avatar
iskra092
lb1120 Single Antenna Compatible?
Hello!   Was wondering if its possible to only utilize a single antena port (1 Yagi) on the lb series, as opposed to a MIMO setup? Plan was to insert the Yago into the MAIN port.   Thanks! ...
