Jo22956
Nov 16, 2017Guide
LB1120 software update fails to install
I just received a LB1120 and checked it for software update. When I click the download button it starts and you can watch the % as it progresses and then it stops and says there was an error and to tr...
hareeshreddy868
Dec 04, 2017Aspirant
I encountered this very same error while LB1120 software update. It stopped responding and automatically closed itself after going till 85% but later it says the update was done. Not sure what happened there so I contacted support been 2 week got no response yet.
- fantaxp7Dec 04, 2017Aspirant
How many bars of reception do you have? Netgear support said I need more than 2. After I got this update going I was going to work on reception....I have two antennas mounted on our roof however reception isn't great. So I am scrambling to at least temporarily get a better signal to complete this much needed update.
- Jo22956Dec 04, 2017GuideI think there is something to having 2 or more bars. I think when mine finally installed that is what I had. I just updated a POE LB1121 that I am switching to and it updated. I had two bars and I did a speed test first and had 10 mb down before I started. Hope you get it to cooperate.
- steboknappDec 06, 2017Aspirant
So the magic solution is to have 2 or more bars of reception? This is so odd. (Say it ain't so!) . I've tried the firmware update 10+ times already and haven't gotten it past 65%
Mine hovers around 3-4 bars and can bump to 5 at times. I'll try again perhaps holding it of a window or something and try to watch if it drops to 2 bars during this next download attempt.
