Jo22956
Nov 16, 2017Guide
LB1120 software update fails to install
I just received a LB1120 and checked it for software update. When I click the download button it starts and you can watch the % as it progresses and then it stops and says there was an error and to tr...
fantaxp7
Dec 04, 2017Aspirant
How many bars of reception do you have? Netgear support said I need more than 2. After I got this update going I was going to work on reception....I have two antennas mounted on our roof however reception isn't great. So I am scrambling to at least temporarily get a better signal to complete this much needed update.
Jo22956
Dec 04, 2017Guide
I think there is something to having 2 or more bars. I think when mine finally installed that is what I had. I just updated a POE LB1121 that I am switching to and it updated. I had two bars and I did a speed test first and had 10 mb down before I started. Hope you get it to cooperate.
