Jo22956
Nov 16, 2017Guide
LB1120 software update fails to install
I just received a LB1120 and checked it for software update. When I click the download button it starts and you can watch the % as it progresses and then it stops and says there was an error and to tr...
fantaxp7
Dec 08, 2017Aspirant
Update on the update....
I bought a $15 antenna on Amazon as a desperate attempt. Turns out it worked, update downloaded within 10 seconds. Had a steady two bars of signal.
So I got all excited and placed back into our server room, played around a bit with the antenna setup as I was shocked the roof mounted antenna's I installed were getting the same or worse reception then no antennas connected....after plugging/unplugging the annena's it has an orange light and only the third reception bar is lit! Rebooted a few times to try to fix but nope....
This thing is really testing my patience.
Jo22956
Dec 08, 2017Guide
Check your SIM card. I got the center orange light if it was installed incorrectly. Hopefully something simple like that. Another thing when you get it working you might discover the modem uses several bands from the tower. Sometimes faster speed is on the weaker signal. Mine will automatically switch to stronger signal that is slower. I think this is the cell tower doing this and not your modem. Best wishes!!
- fantaxp7Dec 08, 2017Aspirant
Thank you, after a couple of time re-setting the chip it worked!
Also you may be on to something with the cell towers. While I was configuring I saw my signal go from 4-5 bars then drop back down to 1.
