KSP1138
Dec 15, 2020Tutor
LB1120 suddenly very slow with AT&T SIM
Hello. We had been using an LB1120 LTE modem for several years when it just failed. We bought a new one, and installed our existing SIM card (AT&T, from the old failed 1120) and it worked great for about one month. I have a secondary remote antenna attached for the best signal. However, we only get about three bars at most. Nevertheless, the speeds were in the 35 up and 20 down range.
However, this week, I noted a very slow connection. Now I'm lucky if I get 6 up and 8 down. I did a factory reset to no avail. As far as I know, it was all factory out of the box. We also have an AT&T hotspot modem which rocks (for us) at nearly 60 up and 30 down consistently. So today I swapped SIM cards. Same speeds, no change. The SIM card that had been in the LB1120 is now in the mobile hotspot, and its speeds are great. So it does not appear to be the SIM card or any data speed cap. I tried unplugging the antenna also. No change in speeds.
What happened? Could something have happened to the new LB1120 to suddenly reduce its speed? Is there some setting I am missing on the device? The only hardware change we made recently was adding several more Google Mesh repeaters to the modem, but the speed drop happened several weeks after that.
Suggestions?
Thanks! CG
You've got a pretty complicate setup there. Not the sort of thing that many people here will have seen. That probably includes Netgear.
Have you talked to AT&T?
One thing to consider with a complicated setup like that is to restart the whole network in the recommended order.
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it connect.
- Turn on computers and rest of network.
You have posted your message in the section of this community given over to Cable Modems, Routers and DSL Modems. (This is easily done, given Netgear's impenetrable community structure.)
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
Mobile Routers, Hotspots & Modems
I will ask the Netgear moderator to move your message.- KSP1138Tutor
Thank you for this! I looked high and low where to post. Inpenetrable is right! Should I, too, try and contact them? CG
