frankowen
Aug 02, 2020Tutor
LB1120 will not auto-reconnect to cell service once it disconnects due to poor signal
I live in an area with spotty service, and my LB1120 will periodically disconnect due to poor signal conditions. However, even when signal improves, the modem refuses to re-connect. It remains discon...
LlamaLarry
Aug 05, 2020Luminary
You have to factory RESET to get back on the network? It doesn't work when doing a reboot?
I have an LB1120 (and an LB2120) and both suck when the cell network degrades and they drop to 3G during a storm. They will never try to reconnect to 4G or LTE automatically. I just have to wait until someone complains that the internet is slow and the only way to force it to reconnect is to reboot.
frankowen
Aug 05, 2020Tutor
Actually, reboot might work too. I'll have to try it. If it does, then I may be able to use a timer to power-cycle the thing a couple times a day. Very frustrating that it just gives up like that. Good to know it is not just my device. Thanks for the reply!
