Ahtir
Jul 05, 2017Follower
LB1121 PoE voltage range?
Hi, What is the supported PoE voltage range in LB1121? How much power does it need when powerd by PoE? Regards, Ahtir
j4y
Jul 25, 2017Guide
bump.. Netgear apparently has no idea how their own device's POE is suppose to work.
What POE standard does the LB1121 use? How many volts and amps are required of the POE injector for this thing to work and restart properly?
