robbrooks33
Mar 27, 2020Aspirant
LB2120 - (4G LTE Modem) Internet disconnects every 10-14 hours
Have recently installed and put into bridge mode connected to an Orbi RB40 as the router. (Firmware on all is up to date) Internet is an unlimited data sim with Three. The internet is intermittent (ha...
JohnPeng
Mar 27, 2020NETGEAR Expert
What do you mean by this:" The internet is intermittent (have to click twice on links to work)"?
I think in the latest FW on LB2120, we support KeepLive PING. Could you please enable it to see whether the data connection drop issue will happen again.
Thanks
robbrooks33
Mar 29, 2020Aspirant
Thanks for the reply - unfortunately I have then enabled and set to 1 minute, it makes no difference. Any other suggestions?
