JumpMaster
Apr 16, 2018Aspirant
LB2120 - Both nics on the same network
Hi all, Is it possible to have the LAN and WAN side of the LB2120 on the same network? I would only like certain devices to be able to use the LTE backup and to control this by having to set the de...
JasonN
Apr 24, 2018NETGEAR Employee Retired
Hi JumpMaster,
This will cause an IP conflict. For example, if you set your LAN and WAN to the same IP address then how will you avoid the ip clashing? Also how would you access the LB2120 interface if they both have the same gateway?
If you have the device already, then you can give it a try and confirm. :]
- Jason N
- JumpMasterApr 24, 2018AspirantHi Jason,
-If I had the device I would try it.
-My picture shows the wan and LAN with different IP addresses.
-I would assume only the wan has a gateway as a router uses the wan gateway to pass traffic outside of the lan.
Kev, - JasonNApr 24, 2018NETGEAR Employee Retired
Hi JumpMaster,
I have talked to my colleague and he said that your setup should work with the setup below:
Please let us know if this works for you. :]
- Jason N
- JasonNApr 30, 2018NETGEAR Employee Retired
Hi JumpMaster,
I just wanted to check in on you and see if that diagram worked for you.
Please let me know. :]
- Jason N
