JumpMaster
Apr 16, 2018Aspirant
LB2120 - Both nics on the same network
Hi all, Is it possible to have the LAN and WAN side of the LB2120 on the same network? I would only like certain devices to be able to use the LTE backup and to control this by having to set the de...
JasonN
Apr 24, 2018NETGEAR Employee Retired
Hi JumpMaster,
I have talked to my colleague and he said that your setup should work with the setup below:
Please let us know if this works for you. :]
- Jason N
JasonN
Apr 30, 2018NETGEAR Employee Retired
Hi JumpMaster,
I just wanted to check in on you and see if that diagram worked for you.
Please let me know. :]
- Jason N
