andymet87
Jan 03, 2020Initiate
LB2120 - default ADMIN password INCORRECT
So I have just opened up my new LB2120 to set it up (ditching my wired broadband in favour of 4G which should boost my broadband speed significantly). However, I have fallen at the first hurdle. ...
iSarge4
Jan 04, 2020Aspirant
On Page 13 of the User Manual (for LB2120), it has a picture of the sticker which is affixed to the LB2120. On that sticker is the word "Reset" with a small hole next to it. Insert the end of a paper clip into that hole and press for 20 seconds (probably 10 seconds is fine) then remove the paper clip from the hole. Now try your admin password that is printed on the same label affixed to the LB2120.
andymet87
Jan 04, 2020Initiate
Thanks both. After a lengthy chat with tech support (and resetting several times) we agreed that the password on the back was wrong. I've now got a replacement and all works as it should. No idea what had happened but the password was simply incorrect..!
- MemoryPhantasmJan 09, 2020Aspirant
@My Wegmans Connect wrote:
Thanks both. After a lengthy chat with tech support (and resetting several times) we agreed that the password on the back was wrong. I've now got a replacement and all works as it should. No idea what had happened but the password was simply incorrect..!Your LB2120 should now restart. At this time, you want to try using the Admin password which is on the sticker of the LB2120.
That is the information I got from the official Netgear LB2120 User Manual.
