blackeyes
Aug 02, 2019Aspirant
LB2120 - Keeps switching between 4G and Broadband
My LB2120 is connected in bridge mode in between a DSL modem provided by my ISP and another Netgear Wifi router (WNR3500). At the DSL modem level, the broadband connection is very stable. I have reaso...
chris12
Jan 15, 2020Aspirant
I'm having the same issue. I received over 110 SMS alerts today where the LB2120 said it was failing over to LTE and then switching back. The cable modem connection was fine all the time, though. I rebooted the device and it has seemed ok for 30 minutes at least.
I'd prefer it if I didn't have to reboot the device as the LB2120 is supposed to be a network resiliance device so I would appreciate an update on what is casuing the issue for us and whether/when the software will be fixed. I'm happy to try changing a setting as a temporary workaround.
Thanks, Chris
JohnPeng
Jan 16, 2020NETGEAR Expert
Hi Chris,
You can log in to WebUI to disable SMS notification for failover faeture as a workaround for now.
Sorry for the inconvenience.
Thanks
