Giebat
Apr 03, 2018Aspirant
LB2120 - Using both ethernet ports for LAN?
I have a business need to have a portable 4G router but I require 2 ethernet ports (LAN) that both have DHCP and can communicate between them as well as connect to internet. Looking at LB2120 but can...
TheEther
Apr 03, 2018Guru
Just connect an Ethernet switch to the LAN port.
Giebat
The thing is that this is supposed to be used as a mobile demo setup and I really want to avoid the extra hardware. So a switch is just an option if I can't find a 4G modem with 2 ethernet ports.
- JasonNApr 03, 2018NETGEAR Employee Retired
Hi Giebat,
I agree with TheEther on this and that the Ethernet switch would be your best resolution on this. :]
- Jason N
