stradivarius2b
Jul 22, 2018Follower
LB2120 : Power Light Amber
Hi,
I bought 2 units of Netgear LB2120-100PES. They are used in France with SFR Operator.
Every few days, the modems are stuck with Power Led Amber, Signal is full and green and network l...
docteurmicro50
Nov 28, 2018Initiate
Hi Michel
Don't waste your time, buy one from another brand. I did the same for 2 customers, no more issues....
I have tested 1 week ago is there is a new firmware from Netgear by OTA, nothing...
Buy a Huawei model...
Julien
SOGAPEX
Nov 29, 2018Aspirant
Hi Julien
in my case, this is "only" a backup internet access point in case our fiber link is down.
By the moment, I set the LB2120 as a "router" (not a bridge => operation mode = router) and I manually selected the FREE network (network selection mode = manual)
I also forced the netgear to always operate in 4G mode (default connexion = mobile broadband only)
By the moment, it seems to work (I deliberately plug out the fiber modem ethenret link yesterday to see how the firewall and the netgear modem would handle it = ok)
This morning, the netgear is still available throught the network (192.168.5.1) and all lights are correct (power light = green)
I will report back if it randomly goes "amber" like it did when set as a "bridge".
But it seems in my case, this was the bridge mode that is not really stable or supported in my network configuration.
Michel D.
- sktmDec 01, 2018Guide
This sounds the same issue as posted here
