LivingwithIT
Mar 28, 2020Aspirant
LB2120 4G modem AT&T / TMobile - SIM Card questions.
Trying to determine the best plan to use with the LB2120: a) Prepaid xGB Data plan SIM card b) Prepaid Unlimited Voice/Txt/Data plan SIM card I looked at both AT&T and TMobile Option a) seems ...
- Jul 07, 2020
The Phone SIM should work with the device as long as it would have a data subscription. - Rhys
RVALENZ
Jul 07, 2020NETGEAR Employee Retired
- LivingwithITJul 07, 2020AspirantAlready got T-Mobile’s unlimited $40 plan. Thanks for the reply anyway.
