LivingwithIT's avatar
LivingwithIT
LB2120 4G modem AT&T / TMobile - SIM Card questions.
Trying to determine the best plan to use with the LB2120: a) Prepaid xGB Data plan SIM card b) Prepaid Unlimited Voice/Txt/Data plan SIM card   I looked at both AT&T and TMobile Option a) seems ...
  • RVALENZ's avatar
    Jul 07, 2020
    The Phone SIM should work with the device as long as it would have a data subscription. - Rhys
