caprock
Jul 03, 2019Tutor
LB2120 4G Modem on Visible prepaid cellular
Have been using this modem with T-Mobile for several months and it works great! I just purchased the budget Android phone, the Visible R2, and activated this new phone from Visible, a Verizon prepai...
ArodiD
Jul 11, 2019NETGEAR Expert
Hi caprock ,
Please check APN profile settings as it may not have automatically setup the APN profile for your new ISP SIM. You can manually set it up via the WebUI and re-check connection.
Arodi
Community Team
caprock
Jul 13, 2019Tutor
ArodiD, thanks for this. In my situation I have three accounts, with the T-Mobile as my primary: APN fast.t-mobile.com, IPV4, IPV4. This is my working device profile.
I have tried two other device accounts: Verizon (post paid) and Visible (prepaid Verizon). The Verizon account works and Visible does not. In both cases, the ABOUT and APN are the same: APN Name: Verizon (vzwinternet); APN: vzwinternet; Authintication: None; PDP: IPV4; PDP Roaming: IPV4.
Drats, this was a good idea to check. I had posted this but apparently not succesfull.
Thanks for this heads-up!
