caprock
Jul 03, 2019Tutor
LB2120 4G Modem on Visible prepaid cellular
Have been using this modem with T-Mobile for several months and it works great! I just purchased the budget Android phone, the Visible R2, and activated this new phone from Visible, a Verizon prepai...
caprock
Jul 14, 2019Tutor
You are ABSOLUTELY CORRECT! It was in fact, the APN setting that was wrong. This took me a while to locate the phone setting and then to spell the APN name correctly.
Thanks for your assist!
SOLVED
mmdavi14
Aug 06, 2019Aspirant
I'm about to attempt this with the M1. Just to be clear, what settings, exactly, did you use to get your LB2120 up and running? Has it been successful so far? Thanks so much for this thread!
- caprockAug 06, 2019TutorAPN Name: Verizon Visible; APN: vsblinteret; Authentication: None; PDP: IPV4; Roaming:IPV4
Note: APN is case sensitive. The APN name is not significant. I now have 2 mobile phone accounts but have not switched the modem yet from T-Mobile to Visible. TM seems tolerant with monthly usage of 50-75gb, fear Vis may not. Plan is to start Vis for the modem soon. 3 things to consider: (1) modem is serviced as a Hot Spot, limited to 5mbits up/down (2) international travel is not supported, cases where Sim card is back in phone. (3) if you have an iPhone 6 or later good to go. Android support is meager. For me, I chose the $99 Visible R2.- mmdavi14Aug 06, 2019AspirantPerfect, thanks! 5mbps seems better than everyone else's 128kbps-600kbps. I'll test their data tolerance pretty heavily, too, but for $20 for the first month, I'll give it a shot.
- GetNear77Aug 24, 2019Aspirant
I have this same question, what's the deal with it suddenly stopping? Is it possible to spoof the IMEI of one of Visible's "approved" devices?
Can anyone else who is using this modem to connect with Visible confirm that their service suddenly stopped working with the modem or is this just area specific?
