caprock's avatar
caprock
Tutor
Jul 03, 2019
LB2120 4G Modem on Visible prepaid cellular
Have been using this modem with T-Mobile for several months and it works great! I just purchased the budget Android phone, the Visible R2, and activated this new phone from Visible, a Verizon prepai...
  • ArodiD's avatar
    ArodiD
    Jul 11, 2019
    Hi caprock ,
    Please check APN profile settings as it may not have automatically setup the APN profile for your new ISP SIM.  You can manually set it up via the WebUI and re-check connection.
    Arodi
    Community Team
