g3rti
Nov 03, 2017Aspirant
LB2120 4G No Signal
Hello, I bougt on amazon.com the Netgear LB2120 (us model) I Live in Europe, Does it work here? Beacuse the 4g signal is dead. Thank you
g3rti
Please help me :(
Does the US version work in Europe?
JamesGL
Nov 09, 2017NETGEAR Employee Retired
Hi g3rti,
The device is only available for US market but let me check if it should work with regions outside US.
- g3rtiNov 11, 2017AspirantThank you, Im waiting for
your reply.- DarrenMNov 15, 2017Sr. NETGEAR Moderator
It would depend on the frequency band the ISP in EU is using as it may not be supported on NA SKU. We don’t recommend using a device which is meant for a different region. We don’t support this.
DarrenM
