magbusser's avatar
magbusser
Follower
Mar 09, 2023
LB2120 AS FAILOVER MODEM FOR NBN
Hello
I have purchased the LB2120 as a failover moden and was wanting to confirm its actual setup as does not apper to be working as a failover
NBN NTU OUT to
WAN IN MODEM/ROUTER LAN OUT to
WAN IN LB2120 LANOUT to [bridge mode with failover activated]
LAN IN NETWORK SWITCH to ALL CONNECTED DEVICES
Should the LB2120 be in this location or betweem the NBNNTU and the modem router??
Both locations have failed so far
Any assistance would be appreciated
Cheers
1 Reply
  • JohnPeng's avatar
    JohnPeng
    NETGEAR Expert
    Please connect LB2120 in the following way to use failover.
    1. Connect WAN port to your home broadband's LAN port
    2. Connect LAN port to your computer
    3. Enable failover. I think this is the default setting.
    Please advise what is your home broadband's type and modem brand and model if this is not working for you.
    Thanks
    John
