electroMechanic
Aug 01, 2018Star
LB2120 cellular band/ frequency selection
I bought one of your LTE LB2120-100UKS Modems, so that I could place it in the best location on our property for 4G LTE Cellular signal reception, whilst considering buying a separate router with a p...
electroMechanic
Aug 07, 2018Star
Just to add a little context, while the device was connected using band 20, the signal strength indicator was showing 4/5, whereas while connected using band 3, the signal strength was showing 2/5.
So the connection using band 3 was actually yielding a substantially superior download speed despite the fact that signal strength was apparently half that of the connection using band 20.
countrywidewifi
Aug 15, 2018Tutor
We have all been asking for this option.
- electroMechanicAug 16, 2018Star
If you can, please upvote/ kudo the idea in the Idea Exchange at the following link, so that we can draw more attention to this problem.
