samny
Nov 18, 2017Aspirant
LB2120 crashing instead of failover
Dear all, I bought a LB2120 configured behind a TP-LINK TD-W8960N. The problem I have is fairly simple: when the TP-LINK is crashing, the LB210 seems to crash also... The led are blinking correctl...
JasonN
Mar 06, 2018NETGEAR Employee Retired
Hi samny & britdoc,
Sorry to hear that you guys are having issues with your LB2120. When you are saying configured behind your TP-LINK TD-W8960N, do you mean hard wired with an Ethernet cable?
Also are the LB2120 up-to-date with the most current firmware?
Please let me know :]
- Jason N
- samnyMar 06, 2018AspirantHi,
Yes the lb2120 is directly connected to the w8960n using a regular ethernet cable.
I observed when the system is stuck, it seems there is a lot of traffic as led are blinking very fast. I tried to add a switch between both to decouple both components, but it continued to crash.
and yes, the lb2120 is using the latest firmware ( I did one upgrade since I bought it)
Regards
Arnaud
