samny
Nov 18, 2017Aspirant
LB2120 crashing instead of failover
Dear all, I bought a LB2120 configured behind a TP-LINK TD-W8960N. The problem I have is fairly simple: when the TP-LINK is crashing, the LB210 seems to crash also... The led are blinking correctl...
JasonN
Mar 06, 2018NETGEAR Employee Retired
Hi samny,
I wanted to confirm with you that the LB2120 was connected to the LAN or WAN port of the TP-LINK TD-W8960N?
- Jason N
