samny
Nov 18, 2017Aspirant
LB2120 crashing instead of failover
Dear all, I bought a LB2120 configured behind a TP-LINK TD-W8960N. The problem I have is fairly simple: when the TP-LINK is crashing, the LB210 seems to crash also... The led are blinking correctl...
pirrup
Mar 21, 2018Aspirant
Hi ,
I have same issue with the LB2120. is on latest firmware and i use it in bridge mode.
so modem to LB2120 and ethernet cable to wan port of my router.
What i noticed is when i loose connection it freezes and power led blinks green.
no more connection on my router and when i reboot router i still don't get an ip from the LB2120 until i reboot it.
It really annoying that you buy this for failover and it's a single point of failure and makes it even worse :(
Kind regards,
pirrup
