showard1017
May 14, 2019Tutor
LB2120 DDNS client
I am implementing the LB2120 in the ROUTER mode and am connecting the Verizon modem directly to the input and run everything on the network created by the LB2120. I have a wireless repeater for all t...
lukeswr
Oct 23, 2019Aspirant
Are you still having issues with the LB2120 and DDNS? Have you found a work around?
Others in the community have indicated problems with the LB2120 not being friendly to DDNS.
showard1017
Feb 02, 2020Tutor
Sorry for the dely . . . Life got in the way.
Still haven't figured it out.
I'm on Verizon with a Actiontec MI424WR Rev. 1 Modem
There is one WAN port
But my limited knowledge is keeping from figuring this all out.
Many of my devices are crashing through the LB2120 and into the Verizon Modem.
Others devices are not.
I don't really understand why some work and others don't and what to do about it.
It has both a WAN CoAx and WAN Ethernet connection.
Is that "two WAN ports"?
Do I connect the LB2120 to the Ethernet WAN port and my Intranet devices to the LAN Ethernet ports?
Or to the LB2120 ports?
If so, how do I reach devices on my Intranet and how do things inside the Intrnet connect to devices on the WAN Internet?
I'm sure someone is shaking their head at my stupidity. Just trying to understand.
S.
