Red93's avatar
Red93
Follower
May 30, 2020
LB2120 Failover Settings
I am totally confused on the failover mode. My internet went down (Cox cable) I have an ARRIS SB6183 cable modem and ASUS RT-AC88U router.. The cellular modem is between the two. The failover IP is set to 8.8.8.8. There was nio automated failover.. I forced it to failover.  When the cable was restored, there was no automated recovery to cable modem connection.. I was not able to get it back off cellular enven after rebooting/turning off then on..etc.. Finally removed the LB2120 from the network..
This is what the purpose of this device is and why I purchased it...
Are there any Bridge settings that must be changed. Seems Netgear has not been able to give a satisfacory response for this issue.
1 Reply
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi Red93
    Welcome to NETGEAR Community!
    Are you still experiencing this?
    Have you tried factory resetting?
    Please provide the device firmware version.
    Blanca
    Community Team
