beachmat
Apr 29, 2022Guide
LB2120 failover
I was looking at the LB2120 as a possible 4g failover option for our wired internet connection. Am I right in thinking that in order for that feature to work with an existing router, that router must have a second WAN port with failover support? The manual doesn't really talk about this and I can't see how it could work with a router with only 1 WAN port.
Thanks
I think page 20 of the manual goes over automatic failover setup.
https://www.netgear.com/support/product/LB2120.aspx
From the manual (it then goes over setup):
The modem provides wireline broadband pass-through with automatic failover support so that you can
connect the modem to an existing DSL, cable, or fiber optics modem (see Connect the Modem to a Wireline
Broadband Modem on page 16). If the wireline broadband connection goes down, the modem can
automatically and seamlessly switch over to the backup Internet connection over the mobile broadband
network for continuous connectivity.This capability is enabled by default.You can manage the IP addresses
that are used in failover detection- beachmatGuide
Thanks - I've seen that, but it just says to connect the modem to an ethernet port on the router. In that case, if the main connection goes down, how will the router know to send internet-bound traffic through the LB2120? I'm not clear.
From my reading you'd be going :
Modem---->lb2120 wan port-----lan port---->router (in either ap mode or the router's ip address in the lb2120's dmz).
By default the lb2120 should just use the modem (hardline) as the data and failover to the mobile connection if the hardline goes down.
Its if you start making changes that it forces either hardlined or data only.
The lb2120 would be acting as in the dual wan (hardline or mobile) capacity and feeding your router (if you had a connected one)
