Avocadodude
Jan 14, 2018Aspirant
LB2120 Firmware update release information
Are release notes posted for LB2120 anywhere? I have about 700 text messages from my router stating firmware update is available, but I can't find information on what it does/fixes.
JasonN
Jan 18, 2018NETGEAR Employee Retired
Hi Avocadodude,
The firmware provided for your modem is through your internet provider which you would need to contact.
- JasonN
Avocadodude
Jan 18, 2018Aspirant
Hi Jason,
Thank you for the reply. I don’t believe that is correct though. The firmware update came from Netgear, there just weren’t any change notes with it.
- JasonNJan 19, 2018NETGEAR Employee Retired
Hi Avocadodude,
Thank you for your response again. So I can investigate into this further, can you please provide a bit more information on this as to what you mean by "the firmware update came from NETGEAR" Maybe provide the exact message of your text?
NETGEAR does provide firmware for many of our products and can be found on the specific product page. If you look at the LB2120 product page, it does not have any information regarding firmware. This supports the information that the firmware is managed by the ISP. Hope to hear from you soon :]
Below I provided the links to the product pages to compare:
https://www.netgear.com/support/product/MR1100.aspxhttps://www.netgear.com/support/product/R9000.as
- Jason N
- JasonNFeb 14, 2018NETGEAR Employee Retired
Hi Avocadodude,
I am PMing you right now to further assist you on this issue.
- Jason N
