Purduephotog
Mar 23, 2020Guide
LB2120 firmware update, where is it?
I'm looking for the firmware for the LB2120 to download, but the download page doesn't show anything available. The device shows a firmware update available, and discussions here indicate one exists....
Blanca_O
Mar 25, 2020NETGEAR Employee Retired
Hi Purduephotog
Welcome to NETGEAR Community!
When an update for LB2120 is available then you will be notified that there is an update available.
May we please know the device SKU (e.g. LB2120-xxx)? This can be checked on the box of the product or on the barcode label.
What is the current firmware version?
Blanca
Community Team
Purduephotog
Mar 25, 2020Guide
Logging into the modem, I see the following:
Software Update Available A software update is available for your device. Download size: 0 KB. You may incur charges for data used during the download. Start Download
This is what I have listed in the 'about' screen:
Firmware Firmware Version: M18Q2_v12.09.163431
App Version: NTG9X07C_12.09.05.27
Web App Version: LBHDATA_03.03.103.165
Bootloader Version:
Bootloader Ver: v1.0.0
Hardware Version: 08
- MaxdoggrayApr 02, 2020Aspirant
How long has firmware update been out? What does affect?
App net map does not show status of cable modem feed.
- PurduephotogApr 03, 2020Guide
Don't know. Can't get it, and don't want to try and download it over cellular without ability to restore. Wouldn't be the first time I've had something brick on a push.
Haven't been able to get an answer yet either.
- JohnPengApr 03, 2020NETGEAR Expert
The latest release includes the following:
App Version: NTG9X07C_12.09.05.30
Web App Version: LBHDATA_03.03.103.175
You should upgrade your device to the latest by clicking the Start Download button.
Thanks
