NapalmCricket
Mar 27, 2020Aspirant
LB2120 IPv6 in bridge mode
I recently purchased a LB2120 to use for failover while working from home for COVID-19. I have it configured for bridge mode with a Google Nest Wifi connected to it as the router. Before configuring ...
JohnPeng
Mar 28, 2020NETGEAR Expert
Please make sure your carrier supports IPv6. When you set up APN, please make sure your APN IP type is set to IPv4v6 in order for you to get both IPv4 and IPv6 address from your carrier.
Thanks
- NapalmCricketMar 28, 2020AspirantHi, thanks for your response. I am talking about the wired connection, when I direct plug my router to my cable modem, IPv6 works fine, when I plug in via the LB2120, IPv6 no longer works.
- Sean101Jun 14, 2020Aspirant
Hello NapalmCricket ,
The LB2120 doesn't seem to support IPv6 on wireline based on the manual. Please try to set it to bridge and let me know.
