Rockit1
Sep 25, 2019Follower
LB2120 lte modem cannot access menu after software update
Hello all, Recently had a software update come through and was installed ok on my LB2120. All seems fine however I can no longer access the menu using the ip 192.168.5.1 Wondering if the IP was change...
Wilde1
Sep 29, 2019Aspirant
I use the LB2120 (connected to my Orbi AC3000 with "bridge" mode) for my home internet, using AT&T LTE service.
After updating the firmware a few days ago, I ran into the same problem. I could no longer log into my LB2120.
Solution: I held down the reset button (small hole in the label on the back of the LB2120) for about 5 seconds to return it to factory settings. Then I was able to log in again on Windows 10.
I've had significantly faster upload and download speeds since the update , but once or twice a day I lose internet and need to reboot the LB2120. Previously I needed to reboot the LB2120 about once every 1-2 weeks.
