ezracat2250
Mar 09, 2021Tutor
LB2120 LTE not detecting WAN "wireline unavailable" with Cirgin Superhub UK
Similar to this issue which does not have a fix confirmed: https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/Netgear-lb2120-wireline-unavailable/td-p/1688697 I've tried differen...
ezracat2250
Mar 09, 2021Tutor
Can't seem to edit on this forum but I meant Virgin Superhub.
- Blanca_OMar 15, 2021NETGEAR Employee Retired
Hi ezracat2250
Welcome to NETGEAR Community!
Kindly change the Failover Detection IPv4 Address to your ISP provided DNS.
Please provide the firmware version.
Blanca
Community Team
- ezracat2250Mar 17, 2021TutorBlanca_O
Thanks I'll try that and report back.
I updated the firmware to latest using the update function I'll report back the version number.
Thanks!- schumakuMar 17, 2021Guru - Experienced User
With a monolithic Cable Modem and Router you can't loop the LB2120 into the the public WAN/Internet Ethernet connection (which in my understanding must be transparent IP, no PPPoE/PPTP/PPPoA or the like encapsulation) as it's shown in the quick start guide and certainly the user manual, too.
As there is only a cable network antenna connector on all these Virgin superhub and hub 3, 4. ..., this set-up is not possible.
if you need this fail-over option, there is no other way than re-configuring the Virgin CPE to a pure modem, and add a dedicated router/wireless router/Mesh router.
