ezracat2250
Mar 09, 2021Tutor
LB2120 LTE not detecting WAN "wireline unavailable" with Cirgin Superhub UK
Similar to this issue which does not have a fix confirmed: https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/Netgear-lb2120-wireline-unavailable/td-p/1688697 I've tried differen...
Blanca_O
Mar 15, 2021NETGEAR Employee Retired
Hi ezracat2250
Welcome to NETGEAR Community!
Kindly change the Failover Detection IPv4 Address to your ISP provided DNS.
Please provide the firmware version.
Blanca
Community Team
ezracat2250
Mar 17, 2021Tutor
Blanca_O
Thanks I'll try that and report back.
I updated the firmware to latest using the update function I'll report back the version number.
Thanks!
Thanks!
- schumakuMar 17, 2021Guru - Experienced User
With a monolithic Cable Modem and Router you can't loop the LB2120 into the the public WAN/Internet Ethernet connection (which in my understanding must be transparent IP, no PPPoE/PPTP/PPPoA or the like encapsulation) as it's shown in the quick start guide and certainly the user manual, too.
As there is only a cable network antenna connector on all these Virgin superhub and hub 3, 4. ..., this set-up is not possible.
if you need this fail-over option, there is no other way than re-configuring the Virgin CPE to a pure modem, and add a dedicated router/wireless router/Mesh router.
- ezracat2250Mar 17, 2021TutorThanks the superhub is in modem mode. So it's running as a pure modem.
I use a nighthawk router connected to the superhub in modem mode. That should meet the intended design- schumakuMar 17, 2021Guru - Experienced User
Ok. Just for the interested community members (I'm far away from where Virgin is providing Internet services): Is there plain IP on this link (no encpasulation, no authentication), eg. can you connect a (single) computer direct to the modem and just get the public IP by DHCP on the adapter?
If yes ... there must be a problem on the LB2120.
