ezracat2250
Mar 09, 2021Tutor
LB2120 LTE not detecting WAN "wireline unavailable" with Cirgin Superhub UK
Similar to this issue which does not have a fix confirmed: https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/Netgear-lb2120-wireline-unavailable/td-p/1688697 I've tried differen...
pm1234
Apr 25, 2021Initiate
I have the LB2120 working with a Virgin Super Hub 3.
The Virgin Hub needs set to modem mode. The LB2120 needs to be set as a bridge. Connect the Virgin hub number "4" socket, to the WAN socket on the LB2120. For some reason the other Virgin hub sockets won't work with this, only number 4 - no idea why.
Then a separate router needs to be connected to the LAN socket of the LB2120.
Then turn everything off.
Turn Virgin Hub back on and wait for a steady green light.
Then turn on the LB2120
Then your router.
The device isn't perfect. I've posted on here about the need for Email alerts in addition to SMS alerts. I just keep on running out of SIM data because I never know when the failover has happened.
- TheNixAug 06, 2021Aspirant
Hi.
I'm having exactly the same problem with exactly the same set-up. I've tried the incremental powering up suggested, but the 2120 still doesn't think that it can see the internet through wireline.
Any other configuration or procedural suggestions welcomed!
- jeromeLSep 01, 2021Aspirant
Hello,
I have the same problem, no internet connection detected, even when forced, it's stuck on 4G
My setup is easy :
Optic to RJ45 module -> LB2120 -> Orbi AX6000
It works directly if I remove the LB2120 so I'm sure it's the problem. Does it needs to have a modem between the Optic to RJ45 and the LB2120 ?
Thank you!
Jérôme
