ezracat2250
Mar 09, 2021Tutor
LB2120 LTE not detecting WAN "wireline unavailable" with Cirgin Superhub UK
Similar to this issue which does not have a fix confirmed: https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/Netgear-lb2120-wireline-unavailable/td-p/1688697 I've tried differen...
TheNix
Aug 06, 2021Aspirant
Hi.
I'm having exactly the same problem with exactly the same set-up. I've tried the incremental powering up suggested, but the 2120 still doesn't think that it can see the internet through wireline.
Any other configuration or procedural suggestions welcomed!
jeromeL
Sep 01, 2021Aspirant
Hello,
I have the same problem, no internet connection detected, even when forced, it's stuck on 4G
My setup is easy :
Optic to RJ45 module -> LB2120 -> Orbi AX6000
It works directly if I remove the LB2120 so I'm sure it's the problem. Does it needs to have a modem between the Optic to RJ45 and the LB2120 ?
Thank you!
Jérôme
