dottodotto
Jun 28, 2022Follower
lb2120 modem
I have an lb2120 connected via google nest home my spped with one user is 70megabit but with 5 users or more speed per user drops to less than 1 megabit is this my netgear moden or my google nest mes...
Jun 29, 2022Guru - Experienced User
The lb2120 has its own integrated router function because it can act as failover for a primary connection from a dsl/fibre/cable connection.
since it has its own router and so does googles, it causes a double nat.
did you try putting the lb2120 in bridge mode? (per page 26 on the manual)
